I just built me a new computer, and its amazing, but the only problem I have is, if I put it in sleep mode, and wake it back up it boots up fine, but when I try to open google to search something it doesn't search, it just sits there and loads for a while and does nothing. it also does the same thing for steam. it will just sit there and say there was an error. but if I reboot my system, it works perfectly fine. any fix for this?
https://linustechtips.com/topic/808321-pc-trouble-after-sleep-mode/
System specs would help, example ryzen had issues early on bios updates help a lot
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
what os are you running? did you do an OS upgrade?
desktop
HTPC
