4 minutes ago, iluminati the 2nd said:
hi i recently put in a case fan but it won't start and i don't know why. anyone know how to fix it?
Hello!
May I ask, would it be possible for you to attach an image of were you have plugged the fan into and what fan model is it?
I once did the unthinkable, back many headphones ago...
I split an audio split, again
https://linustechtips.com/topic/807083-case-fan-wont-start/#findComment-10138148
40 minutes ago, EnergyEclipse said:
Hello!
https://www.startech.com/m/Computer-Parts/Fans/Quiet-925cm-Dual-Ball-Bearing-Case-Fan-with-TX3-connector~FAN9X25TX3L
https://linustechtips.com/topic/807083-case-fan-wont-start/#findComment-10138321
21 minutes ago, iluminati the 2nd said:
33 minutes ago, iluminati the 2nd said:
its a 92mm case fan with 3 pin connector from star tech
1 hour ago, EnergyEclipse said:
Hello!
The one on the motherboard is 4 pin my conector is 3pin btw
https://linustechtips.com/topic/807083-case-fan-wont-start/#findComment-10138391
