Just built my first PC and am super excited about it. Thankfully I barely got a 1060 before they went out of stock everywhere. Total cost was about 900 all in including windows. Thankfully I saved some money by using the stock wraith cooler which seems to do well enough and my friend Cody gave me his old NZXT case. Gaming as well as work is amazing and buttery smooth on my LG 29inch ultrawide 5ms 75hz IPS 1080 monitor and the 1060 does great at staying between 60-75fps for all my games on very high-ultra settings. Learned a lot while building and thanks to everyone for being so helpful and insightful. Cant wait to build a better one down the road.
Parts:
Ryzen 5 1600 (using included wraith cooler) $210
EVGA 1060 SSC graphics Card  ($280)
Corsair 16gb 3000 RAM ($126)
MSI B350 PC MATE Motherboard ($90)
Corsair 550W 80+ Gold Power Supply ($50)
WD Blue 1TB Hard Drive ($47)
SanDisk 120gb SSD ($60)
https://linustechtips.com/topic/806774-first-pc-build/
Nice. Even the color seemed to match.
Desktop benching:
https://linustechtips.com/topic/806774-first-pc-build/#findComment-10134999
Nice build mate :)
Stock cooler from Ryzen does great job, at least at stock and mild overclock.
if you want to push over 3,7GHz on all cores, get some other cooler. But I'm pretty sure that you don't feel the need to overcock just yet, since even at stock settings that CPU is a beast.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/806774-first-pc-build/#findComment-10135069
