So, I am starting to plan the assembly of my new build and the airflow bothers me a bit. The case is the Mercury S8 from Caselabs and this image is almost identical except for the front intake which is shown as 240mm while mine has 360mm and my top cover is extended to allow for push/pull. Anyways, my initial idea is as follow, blue is air in and red is air out. Since hot air rises, seems logical to me that the rad at the top becomes an exhaust (push/pull) with the 140mm fan next to the cpu socket (the mobo is flat in this case). The radiator at the front cover and the one at the bottom of the side panel would both push air in. Seems about right?
CPU: Intel Core i9-10900K  MOBO: ROG MAXIMUS XII FORMULA GPU: 2080ti Hall of Fame 10th anniversary limited edition  PSU: Asus ROG THOR 1200W  COOLER: Optimus foundation black acetal RADS: 3x EKWB CoolStream PE 360  LOOP: EKWB torque HDC fittings / EKWB ZMT 15,9/9,5mm / EKWB CryoFuel Clear MONITOR: Acer predator X34
https://linustechtips.com/topic/805451-case-airflow-feedback/
why do you need 3 radiators?
https://linustechtips.com/topic/805451-case-airflow-feedback/#findComment-10120342
7900x 5ghz
https://linustechtips.com/topic/805451-case-airflow-feedback/#findComment-10120344
11 minutes ago, TheRedViper said:
7900x 5ghz
I think you are going to hit limitations of heat transfer at the IHS before utilizing all of the radiator space there, but it doesn't necessarily hurt either as long as you have good enough fans to provide enough intake through the radiators.
Gaming build:
CPU: i7-7700k (5.0ghz, 1.312v)
GPU(s): Asus Strix 1080ti OC (~2063mhz)
Memory: 32GB (4x8) DDR4 G.Skill TridentZ RGB 3000mhz
Motherboard: Asus Prime z270-AR
PSU: Seasonic Prime Titanium 850W
Cooler: Custom water loop (420mm rad + 360mm rad)
Case: Be quiet! Dark base pro 900 (silver)
Primary storage: Samsung 960 evo m.2 SSD (500gb)
Secondary storage: Samsung 850 evo SSD (250gb)
Server build:
OS: Ubuntu server 16.04 LTS (though will probably upgrade to 17.04 for better ryzen support)
CPU: Ryzen R7 1700x
Memory: Ballistix Sport LT 16GB
Motherboard: Asrock B350 m4 pro
PSU: Corsair CX550M
Cooler: Cooler master hyper 212 evo
Storage: 2TB WD Red x1, 128gb OCZ SSD for OS
Case: HAF 932 adv
https://linustechtips.com/topic/805451-case-airflow-feedback/#findComment-10120401
In spacy case you can do whatever you like. Hot air rising isn't factor inside PC case where fans are moving air. That fact only matters outside the case and if case if placed in tight spot, like under table.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/805451-case-airflow-feedback/#findComment-10125759
