7 minutes ago, Westy55 said:
I need a pc for gaming and recording please include windows, and a keyboard  my budget is 1000 US dollars
I can't recommend anything as of right now since all the prices on graphics cards are through the roof.
lttstore.com
https://linustechtips.com/topic/805126-pc-help/#findComment-10117027
Consider this: https://pcpartpicker.com/list/GyddQV
Get a 1600X if possible, and as @Being Delirious mentioned, wait to buy a GPU if possible because of the mining market.
That build outline is pretty rough, but consider a different PSU (power supply unit) and another stick of RAM.
https://linustechtips.com/topic/805126-pc-help/#findComment-10117033
If you do need something now i'll recommend this.
PCPartPicker part list: https://pcpartpicker.com/list/JCWzcc
Price breakdown by merchant: https://pcpartpicker.com/list/JCWzcc/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($199.99 @ SuperBiiz)
Motherboard: Asus - STRIX X370-F GAMING ATX AM4 Motherboard  ($189.99 @ B&H)
Memory: GeIL - EVO POTENZA 16GB (2 x 8GB) DDR4-3000 Memory  ($104.99 @ Newegg)
Storage: ADATA - Ultimate SU800 256GB 2.5" Solid State Drive  ($94.49 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.79 @ OutletPC)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB FTW GAMING ACX 3.0 Video Card  ($169.89 @ B&H)
Case: Corsair - 270R ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: SeaSonic - S12II 620W 80+ Bronze Certified ATX Power Supply  ($34.90 @ Newegg)
Total: $892.03
Generated by PCPartPicker 2017-07-09 18:59 EDT-0400
lttstore.com
https://linustechtips.com/topic/805126-pc-help/#findComment-10117035
Get a 1600X if possible.
No need for a 1600X, just overclock a 1600.
On that board you can't however, but a b350 board is only $20 more.
https://linustechtips.com/topic/805126-pc-help/#findComment-10117044
I'd recommend this: https://pcpartpicker.com/list/ByNxM8
https://linustechtips.com/topic/805126-pc-help/#findComment-10117046
On that board you can't. however a b350 board is only $20 more.
My bad, forgot to add a B350 board in there. I'm not well informed on how well the Ryzen chips overclock, so thanks for pointing that out.
https://linustechtips.com/topic/805126-pc-help/#findComment-10117051
$1060 for a 1600 and 1070, but GPU's are stupid over priced at the moment, if they weren't over priced it'd be about $100 less. Gets windows from Kinguin for $20-30. Cheap keyboard from eBay/Amazon will be good enough until you can get a fancy one.
https://pcpartpicker.com/list/WgfnvV
https://linustechtips.com/topic/805126-pc-help/#findComment-10117059
Just now, TheSneakinSpider said:
oh yeah will the recording include editing
No. Editing comes after recording and makes the recording look better on YouTube :)
https://linustechtips.com/topic/805126-pc-help/#findComment-10117067
2 minutes ago, Septimus said:
Since the plan is also to overlcock the R5 1600, a cooler would probably be a good idea. If you don't mind, you could do something as generic as the Cooler Master Hyper 212 Evo.
https://pcpartpicker.com/list/4Kmmcc what do u think about this
https://linustechtips.com/topic/805126-pc-help/#findComment-10117093
