Don't have a PS4 just yet but doing my research on HDDs to upgrade once I pick up a PS4.
So I found specs that the PS4 HDD tray will take any laptop 2.5"HDD up to 12.5mm height.  I would love to install a VelociRaptor(10k RPM FTW) into the PS4 but its 15mm in height. Wondering if I cut out the top of the tray will the black shiny cover still fit? I think it would.
Could someone please measure the HDD black shiny cover plate height for me?
Also any idea about this would be great too.
Thanks
Parvum Systems S1.0, 3570K, H100i, Asus Maximus V Gene, Crucial Ballistix Tactical Tracer 16GB @ 1866, EVGA GTX 680 FTW+, Samsung 840 Pro 128GB SSD, WD Velociraptor 600GB HDD, Corsair AX850
https://linustechtips.com/topic/80366-ps4-hdd-tray-modding/
Thanks
Don't know if you can. An SSHD would truly be great (once after caching the data) for the console. You might have to take a close looks at the tear down to see.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/80366-ps4-hdd-tray-modding/#findComment-1101806
Do NOT put a VelociRaptor in the PS4. Put in an SSD or SSHD. The VelociRaptor pulls too much power for the PS4.
https://linustechtips.com/topic/80366-ps4-hdd-tray-modding/#findComment-1101809
I completely forgot about power draw! Shit...
https://linustechtips.com/topic/80366-ps4-hdd-tray-modding/#findComment-1101812
Seagate Hybrid Drives
idle: 1.1v
Read/Write: 2.7
VelociRaptor
idle: 4.2v
Read/Write: 5.1v
Most all laptop HDD Requirements are 8.5v between a 5v and 12v rail. Knowing Sony will not replease power brick spec I feel it's in the same spec as a laptop.
I have to do more research to see if the VelociRaptor will work. Maybe ask Linus to try it???
https://linustechtips.com/topic/80366-ps4-hdd-tray-modding/#findComment-1101932
I doubt it.
https://linustechtips.com/topic/80366-ps4-hdd-tray-modding/#findComment-1101936
I doubt it.
yea Linus probley won't.   But still hopefull to see if the VelociRaptor will work. You never know till you try. If not I can alway put another VelociRaptor in my PC.
https://linustechtips.com/topic/80366-ps4-hdd-tray-modding/#findComment-1101950
of course
Sadly :(
It would make an interesting test though...
https://linustechtips.com/topic/80366-ps4-hdd-tray-modding/#findComment-1101960
you can put whatever you want in it if you cut out the top bit... seems like a shame to do that though why not use a sata extender or something like that
i could use a extender but still will need to modd the area to fit the HDD.
https://linustechtips.com/topic/80366-ps4-hdd-tray-modding/#findComment-1107297
How is it going to fit? VelociRaptor drives are 3.5" not 2.5". Save yourself the trouble and just use a larger capacity 5400RPM drive. In most cases even an SSD only saves you a couple of seconds over the stock HDD, so you're not going to notice the difference a 10000RPM drive will make.
https://linustechtips.com/topic/80366-ps4-hdd-tray-modding/#findComment-1108946
VelociRaptor is a 2.5" drive and the laptop version doesn't come with the 3.5" heatsink mount that the 2.5" VelociRaptor is screwed to on the decktop version.
I have two VelociRaptors in two system I currently use. The differents is clear between 5400rpm drive vs 10k rpm but not earth shaking speed vs a SSD. I don't want a SSD due to all the reads and write it will be doing for the 10yr  life of the PS4 the SSD may fail way sooner them a HDD.
https://linustechtips.com/topic/80366-ps4-hdd-tray-modding/#findComment-1111698
