Can't get lan wall outlet to work properly
Solved by NZLaurence,
You need to change the following wires on the wall plate so that they are wired the same as the label on the back of the wall plate. Do not change the RJ45 end as that is correct.
Once the wires on wall socket are changed then it should work.
EDIT: The punch down block on the back of the wall plate is arranged that way to make it easier to use, they are not arranged in the same order as the pins on the front of the wall plate. You have to follow the wiring guide on the back of the wall plate for the wall plate end only.
The RJ45's are always wired following Either A or B spec:
