PCIe vs USB wifi adapter
26 minutes ago, revsilverspine said:https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed - a guide on wireless transfer speeds.
Antennas on PCI cards are adjustable so you can have them not be in the way of anything else. Additionally, there are cards with antennas that can be mounted separately (antenna is connected via a cable to the card itself as opposed to plugging into the card directly).
I wouldn't recommend using a usb extenstion cable due to loss on cable (may or may not be significant).
There are either PCI cards or PCI-e 1x cards (there's actually a card for pretty much any form of PCI or PCI-e). They're generally pretty small and shouldn't impact your GPU's cooling. Just look on the motherboard, see which PCI is the lowest and use that or use the 1x PCI-e slot above the GPU.
Thanks for the article. I think I might just go for PCIe, since my concern does not seem like a problem. The prices are actually acceptable for both, so yeah.
