Hi guys,
I would like to get some advice about my recent build.
Specs:
-Asus z170 ProGaming
-I7 7700K
-2 * 8gb Corsair vengeance DDR4 @3000mhz
-1080Ti Strix OC 11Gb
-Kraken X62
-Samsung SSD 500GB evo 840
-2 HDD's (2 & 3 TB green WD's)
-Seasonic X560
-3*140mm fan + 1 120mm fan
So, I renewed all except for the MOBO, RAM and PSU.
Now I've encounter some issues which might happening because of the PSU. Especially GPU driver failures.
So, before buying a new one, what wattage would you guys rate my system?
I see a max powerdraw out of the wallsocket of 510watt and an average, while gaming 1440P AAA titles 400-450watts.
I know it is a bit on the high side for the Seasonic X560 but I think it can handle those amps without a problem.
So, question is: what wattage would you rate my system and what powersupply (wattage - brand - why) would you advice?
If I must buy a new one I lean towards Seasonic again.
thanks
https://linustechtips.com/topic/802764-psu-replacement-thoughts/
Did you reinstall windows after your upgrade?
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
2 hours ago, Davedi said:
Hi guys,
Specs:
-I7 7700K
-Kraken X62
-Seasonic X560
thanks
There's no 560W Seasonic unit. I think it's an X650, which actually exists and provides more than enough power for your system.
Ah, well my first Google went wrong and it appears that there's an old 560W version. It should still supply more power than your system demands though.
There is. While it didn't have the "2" within the model number, the Seasonic X *60 models were the KM2 models rather than the X 650 KM3.
Well my first Google must have gone catastophically wrong then cuz my second Google turned up results...
https://www.google.com/search?q=seasonix+x560&rlz=1C1CHZL_enUS742US742&oq=seasonix+x560&aqs=chrome..69i57j0l5.1919j0j7&sourceid=chrome&ie=UTF-8
Seems a little older but it should probably be fine for OP.
That is the only thing I didn't.
Would it matter? it could but I rather spare me all the work if it would be necessary. I make it a last way out.
If nothing else helps I think that would be the last thing to do.
There was and still is an X560 Seasonic ;-)
As for what I can calculate I think my cpu would be sufficient for this build.
It's true that what's needed from him/her is pretty demanding but I cannot believe that the PSU is the cause of my driver failure.
It says that the driver stopped responding and has been repaired.
If I would like to keep things a bit efficient I rather go with a 650 to 700Watts +gold psu, right?
Would be the best investment anyhow. CPU and GPU are pretty hungry.
That's the first thing you should do
HOLA NIGHT THEMERS
OTHER TECH I OWN:
Well, to be honest, never done that when changing hardware.
I did when I placed the new cpu and ram but was using a GTX1070strix at that moment.
Now I just removed the drivers (ddu) and the 1070 and plugged the 1080ti in. Reboot and cleaninstall nvidiadrivers.
But I'm making a backup now so I can reinstall windows again.
Hope it gives me some improvement.
