Hello all,
So im going to be building my first pc in 3-4 weeks time, and i have all my parts chosen out apart from ram. I dont really understand how RAM works. What does dual channel and quad channel mean? Can i buy one stick, and then add another, or do i have to buy a kit of 2 sticks. Im going to be running an r5 1600 and 8gb (2x4) of corsair vengeance lpx 3200mhz. Can i add 8 more gb (2x4) of the same ram in the future, to make for 16gb, or do i need to buy a seperate 2x8? Does dual channel mean that there can only be 2 sticks?
thanks,
-Lukas
1000$ PC: CPU:AMD Ryzen 5 1600 @3.6ghz Motherboard: Gigabyte AB350 Gaming-3 RAM: 16gb Corsair Vengeance 3000mhz GPU: Gigabyte GTX 1060 6gb G1 gaming Storage: 2tb Seagate Barracuda 7200rpm PSU: Corsair Vengeance 550m Case: NZXT S340 Black/Red Keyboard: Corsair Strafe w/ cherry mx browns Mouse: Steelseries Sensei 310
https://linustechtips.com/topic/802688-ram-help/
Dual channel refers to how much bandwidth the CPU can do. Basically, if you're CPU supports dual channel it means it can talk to two "channels" of ram at the same time.
Say you had two sticks of ram, each running at 3000 MHz. Since your CPU supports dual channel, it can talk to both ram sticks at the same time, technically doubling the bandwidth your CPU has to your ram compared to if you had one stick of ram.
However, if you had four sticks of ram, all running at 3000 MHz, with a dual channel CPU, bandwidth would still be the same as if you had two sticks. Remember, your CPU is dual channel, so it can only talk to sticks of ram at a time. Your CPU will treat two sticks of ram as one channel, so to the CPU it seems like you have two larger sticks of ram. Bandwidth is still the same as if you had two sticks of ram.
Quad channel is basically dual channel except your CPU can talk to four sticks of ram at the same time.
You can buy 2x4gb right now, and later on if you need more ram you could buy another one if the same kit, add it in, and you would have 16gb.
It is also possible for you to only have one ram stick, your CPU would just have half the bandwidth compared to two (you only have one stick, so only of your CPUs channels are "occupied").
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/802688-ram-help/#findComment-10091533
Ok, thanks a lot :)
Ill get 2x4 of corsair vengeance now, and then later add another 2x4 once i have the money and feel the need.
Thanks a lot for the response :D,
-Lukas
https://linustechtips.com/topic/802688-ram-help/#findComment-10094610
