What are you setting the offset to and with what program?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/802507-asus-strix-1070-oc-help/#findComment-10089866
Just now, Zackskiller said:
I have msi afterburner. i was using a 50 core offset and 200 memory offset before i set it to stock.
What are you testing it with? What temps? Is power draw maxing out?
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
https://linustechtips.com/topic/802507-asus-strix-1070-oc-help/#findComment-10089874
1 hour ago, Zackskiller said:
Hey guys, im looking to overclock my GTX 1070 Strix card but i think i must be doing it wrong as any possible change sees the card being unstable. could anyone please assist me in overclocking my card?
Thanks.
overclocking is unstable when temps are too high, frequencies are set too high, or voltages are too low. If you wish to maintain stability you must change your parameters.
Here is the basic TL;DR of all overcllocking: In order for your frequency to get higher you must increase your voltage. if you're unable to increase your voltage then you must reduce your temperatures. If you're unable to reduce your temperatures or increase your voltage then you must decrease your frequency (from whatever it is currently set) if you wish to maintain stability.
https://linustechtips.com/topic/802507-asus-strix-1070-oc-help/#findComment-10090011
