Using a voice transformer with an audio interface/mixer
1 minute ago, lazygood4notin said:Ok I think I see what you mean, so let's say if I wanted to record in mono. I connect my mic into the XLR input on the VT-3 like normal, then I would take a 1/4" to XLR cable and plug it into where it says mono on the VT-3: https://gyazo.com/e20d4908a5521decb055e185b40b97ff And then connect the XLR end of that to the mic input 1 on my interface?
If you're controlling the wet/dry mix on the VT-3 then yes. If not then you should connect both the mono output and the dry output to the interface so you record both.
3 minutes ago, lazygood4notin said:And if I wanted stereo I would do the same except I would use both of the 1/4" jacks on the VT-3 and both of the XLR ends would go into inputs 1 and 2 on the interface? That's the only part I'm kind of confused about
Yes. You then need to use the VT-3 to control the wet/dry mix.
