VGA and Streaming question
The streaming software will allow you to encode the content using either your processor, or your video card (if the video card has the functionality built in).
Modern video cards have hardware encoders which can compress the video in real time, without using a lot of processor power. The software you use (OBS for example) simply generates 25 to 60 pictures a second (depending on your choice), "uploads" the picture into the video card, the video card compresses it and then the software "downloads" the compressed image and puts it in the stream of data that is sent to Twitch or Youtube or some other streaming service.
If your video card is of an older type that doesn't have some hardware encoder built in, the software can still compress whatever you want to stream, but will have to resort to using your computer's processor to do the compression. Video compression is quite complex so in the past, this process of compressing the video would use a lot of processor time, and therefore games would run slower because the game also used the processor for some things so now the game had to wait to use the processor for its needs.
However, you have a Ryzen processor which has 8 cores and 8 threads, so a total of 16 cores (8 being "virtual). Older games can barely use more than 2 cores, so even if the capture software uses a lot of processor to compress the video, there would still be at least one or two cores fully available for those games so those games won't have any noticeable drop in performance.
Most tutorials out there about streaming push using hardware encoders (on video cards) because a lot of people have weaker processors with only 2 or 4 cores and more processor-intensive games, so the slowdown caused by using processor to encode your stream could be noticeable and annoying.
It won't be the case with your computer.
