Posted July 2, 2017 Hi All, I want to build a NAS, where I live things are expensive so basically this build is the cheapest thing I could build. Intel Core i3 7100 $ 162.50 Mother Gigabyte Ga-h110n $ 100.00 Memory Corsair DDR4 8gb 2400mhz Vengeance Lpx $ 87.50 Western Digital 2tb Red $ 125.00 Case Raidmax Element Black Mini Itx $ 50.00 PSU Corsair VS 450w $ 62.50 Cooler Corsair Air Af120 x2 $ 50.00 Total $ 637.50 U$D Argentina prices ¯\_(ツ)_/¯ Also, previous generation stuff has same price as new generation parts. That's the reason i picked 7xxx and DDR4. The idea is to run FreeNAS and use to store personal data and as a Plex Media Server. And maybe in the future, personal cloud and a second 2TB WD Red. 2 or 3 video simultaneously on cellphones and the movies are will be stored 1080p <<< I don't know if you guys needed this data, but well here it is. Can it handle that workload? If the question is too stupid, sorry I never builded something like that. Also I do not know how to measure CPU capabilities, yet. In case you guys say the RAM is short I would like to know WHY!? Because I ran a couple of test with VirtualBox with 4GB and I saw no problem at all and all over the internet people are saying 16, 32, 64GB. Link to comment https://linustechtips.com/topic/801605-nas-build-help/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 2, 2017 yeah it should be able to handle the workload. 8gb is recommended, ive used 8gb with my i3 530 server and it worked. nothing major, or even close to what you did though. just me transferring files as a NAS through FTP, it was using 6gb of ram Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017) Samsung 850 EVO 240 GB 138 is a good number. Link to comment https://linustechtips.com/topic/801605-nas-build-help/#findComment-10080222 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 2, 2017 Yes, if your plex media are all in h264 and don't require much transcoding and alot of users. 8GB is fine, you are just running plex media server. I had no major problem running plex and a few other services (sonar, transmission). You might want to look for ecc memory and compatible motherboard if u can. Magical Pineapples
