USB 3.1 Card
Go to solution Solved by suchamoneypit,
Yes and yes
that is the exact purpose of these add-in cards.
Simple question: can I hook this card
https://www.amazon.com/Rosewill-RC-509-Expansion-SuperSpeed-Connector/dp/B01MRSTZXX/ref=sr_1_2?ie=UTF8&qid=1498964139&sr=8-2&keywords=usb+type+c+pcie+card
to this motherboard?
https://www.asus.com/Motherboards/ROG-STRIX-B350-F-GAMING/
in other words, that strix motherboard only has Type A, it doesn't have Type C
so can I buy a PCIe card with Type C and connect to this motherboard or do I need a board that comes with type c?
cheers
https://linustechtips.com/topic/801553-usb-31-card/
cheers
You can connect that card to that motherboard, yes.
But I'm not sure I understand the second bit of your question.
https://linustechtips.com/topic/801553-usb-31-card/#findComment-10079639
Yes and yes
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/801553-usb-31-card/#findComment-10079641
I'm sorry I was in rush when typing this.
the strix board only comes with type A usb. the asus motherboard that comes with type A and Type C USB connectors is $250 (Hero) so i thought i'd buy a cheaper board + type c card.
https://linustechtips.com/topic/801553-usb-31-card/#findComment-10079648
There's two motherboards? Why didn't you mention that in the opening/first post?
https://linustechtips.com/topic/801553-usb-31-card/#findComment-10079650
sorry about that.
Strix does not have type c
Hero does have type c
strix costs $100 less than hero
third party type c card costs $25
so i figured it was a good idea lol
https://linustechtips.com/topic/801553-usb-31-card/#findComment-10079658
