I'm using an RX 480 and since AMD ReLive came out I have had the same problem and no update has fixed it. When recording a game or my desktop the audio is really quiet, however my microphones audio is fine. I have no clue why it is doing this and if anyone knows anything please tell me.
https://linustechtips.com/topic/801502-amd-relive-audio-problem/
Use OBS instead.
1 minute ago, Enderman said:
Use OBS instead.
CPU heavy but free
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
3 minutes ago, Billy_Mays said:
CPU heavy but free
You can set OSB to use the GPU encoder (even though GPU encoding on AMD GPUs is complete crap).
