Wait I thought you can't even buy a RX 480/580 now or their prices are incredibly high?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/801217-mini-itx-card/#findComment-10076037
They are both are both going to be hard to find (Especially 580s), and I dont even think there are any small 580s.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/801217-mini-itx-card/#findComment-10076040
19 minutes ago, WillBlake said:
Anyone knows if there is a version of RX580 or sth similar that is 210mm?
As far as I know there isn't a mini edition. Maybe due to the thermal issues of the RX cards. Also, it would be pretty dumb buying a RX580 right now that the prices are nearly on the level of a GTX 1070, which is 60% faster. I'd suggest either the Gigabyte GTX 1060 ITX or the GTX 1070 ITX, since prices for AMD cards are so fuckd right now.
https://linustechtips.com/topic/801217-mini-itx-card/#findComment-10076061
Just as I thought :(
But can 1060 do 1440p at 60hz tho?
https://linustechtips.com/topic/801217-mini-itx-card/#findComment-10076090
Med-high perhaps, though they are also becoming hard to find.
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/801217-mini-itx-card/#findComment-10076093
There's still stock on Amazon I guess I'm lucky?
For now, they too will likely disappear soon, buy soon if you are going to.
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/801217-mini-itx-card/#findComment-10076103
a 1060 will be hard pushed to get that, and will likely not keep up in the future (within the next 2 years).
Your only option is to get used graphics card since you mentioned that the GTX 1070 mini cards are too expensive. In that case, help comes from AMD. The older R9 Fury X (watercooled, so it needs a space for 120mm radiator on the case for itself) or R9 Nano (air cooled, but make sure you add as much case fans as you can to prevent thermal throttling) are nice picks for your usage. They should be more affordable than a 1070, but are quite rare.
Desktop benching:
https://linustechtips.com/topic/801217-mini-itx-card/#findComment-10076105
