Just now, NCIX Lampy said:
I don't think it has an option for SSDs though
Thats what I thought?
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
https://linustechtips.com/topic/800899-drive-wipe-for-ssds/#findComment-10072554
8 minutes ago, NCIX Lampy said:
Here's a video saying that DBAN doesn't work for SSDs...
While it's true that currently Dban doesn't have the secure option for SSDs, it still wipes data off of your drive. I've used it on multiple ssds, and tried to recover the data after with no success. Once it's gone, it's gone.
The disadvantage to using dban is that it's slower than a program that can secure erase it.
Anyway if you're paranoid about dban not properly erasing your data, then try PartedMagic.
https://linustechtips.com/topic/800899-drive-wipe-for-ssds/#findComment-10072670
2 hours ago, NCIX Lampy said:
So, I'm using a program that came with my SSD and it won't let me secure erase my SSD. I'm looking to wipe my SSD using other methods, any ideas?
Just burn it
||| Drakon (Desktop Build) |||
|| CPU: 3800X || Cooler: Kraken X63 || Motherboard: B450 Aorus M || Memory: HyperX DDR4-3200MHz 16G ||
|| Storage: 512GB 970 Pro + 500GB 850 EVO + 250GB 850 EVO + 1TB HDD + 2TB HDD || Graphics Card: RX 5700 XT Red Devil || Case: Thermaltake Core V21 || PSU: XFX XTR 750W 80+Gold ||
https://linustechtips.com/topic/800899-drive-wipe-for-ssds/#findComment-10073291
1 minute ago, NCIX Lampy said:
Right, not try and save the drive, but rather just fucking flat out burn it.
Think before you post
It solves the problem...
https://linustechtips.com/topic/800899-drive-wipe-for-ssds/#findComment-10073313
Diskpart is my preferred method. Just run once or twice and you're golden.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/800899-drive-wipe-for-ssds/#findComment-10073916
Link?
What?!
Win + R
"cmd"
"diskpart"
Click yes.
"list disk"
"select disk #"
"clean all" or "clean all override"
Get some lunch or dinner. Take your dog for a walk. Go play "real life" (graphics are a little lower than Witcher 3), but it's fun sometimes.
Done.
https://linustechtips.com/topic/800899-drive-wipe-for-ssds/#findComment-10073946
Not sure what you mean by that
It'll take about [two] hours to complete as it zeroes every bit on the drive.
Sidenote: Apparently spellcheck doesn't check verb or noun spelling differences for "zero"...
https://linustechtips.com/topic/800899-drive-wipe-for-ssds/#findComment-10073989
3 hours ago, ARikozuM said:
It'll take about 2 hours to complete as it zeroes every bit on the drive.
Isn't the proper format supposed to be "two" instead of "2" in that case? I was told something about 10 or under.
https://linustechtips.com/topic/800899-drive-wipe-for-ssds/#findComment-10073996
Spellcheck is telling me that "zeroes" is incorrect spelling, but that only applies to the noun "zero" whereas I'm using "zero" as a verb.
And yes, in transcription, you always write numbers lower than 10 as they are until you achieve numbers that are reducible, i.e. two million dollars and one cent rather than $2,000,000.01 while $2,123,456.78 is better than [insert text here].
https://linustechtips.com/topic/800899-drive-wipe-for-ssds/#findComment-10074009
