1050TI wont work
Go to solution Solved by WhyAmIHere,
Sorry, it will go back to the shelf I took it from, I'll use it for a friends build or an extra small gaming righ of my own.
Thank you for your help :)
4 hours ago, Dutch-stoner said:
If you can't get it to work, but if you can confirm the GPU works, I might have another solution: sell it for cheap to me. :P
Hi everyone,
So I had an 1050TI laying around and I want to put it in my HTPC but I can't make it work. According to PCPartPicker the 1050TI should work with my mobo (AM1H-ITX) and my CPU (AMD Athlon 5350 APU).
Bios is up to date, all the drivers and firmware I can download are downloaded and installed, primary video output in the BIOS is PCI.
Anyone had this issue with a similar hardware config and was able to fix it or have any idea on how to fix this?
Hardware:
GC: Zotac 1050TI OC
CPU: AMD Athlon 5350
MOBO: Asrock AM1H-ITX
PSU: Thermaltake TR2 430W
Software:
OS: Windows 10
P.S. Thanks in advance, and i know it's old hardware (beside GC) it's for a HTPC, not for gaming, it's for streaming,
https://linustechtips.com/topic/800851-1050ti-wont-work/
So here is the situation
-Onboard output works fine
-No output on GC
-GC fans are spinning
-15 minutes ago I could see the card as 'unknown material' now I just don't see it at all
-No 6 or 8 pin connectoron the card
-MOBO have one PCIe 2.0 x16 connector
12 minutes ago, Dutch-stoner said:
Is it outputting on the mobo vid output port? In other words, is your bios properly configured? Have you used an GPU before on this machine? Does your 1050ti require an 6 or 8 pin connector? (I read that some of them DO require external power...)
https://linustechtips.com/topic/800851-1050ti-wont-work/#findComment-10072001
-Output on onboard HDMI perfectly
-No output on HDMI
-CG fans are spinning
try setting the bios to boot from your dedicated card, maybe disable the onboard gpu
Have you tried to perform a sudden temporary interrupt of the electricity flow to your computational device followed by a re-initialization procedure of the central processing unit and associated components?
Personal Rig Specs
CPU: Intel Core i7-7700K @ 4.8GHZ
Motherboard: Asus ROG STRIX Z270H GAMING
Graphics Card: Inno3D ICHILL GEFORCE GTX 1080 TI X3 ULTRA
RAM: Corsair Vengeance LPX Black DDR4 2x8GB @ 3GHZ
Storage: 2 x Samsung NVMe SSD 960 EVO 256GB in Raid | 2 x Seagate 4TB Expansion Desktop
(seagates are originally external drives removed from casing and installed internally)
PSU: Seasonic Prime Titanium 850W
Case: Mission SG GGX 3.5 (same as Rosewill Cullinan or Anidees AI Crystal with other stock fans)
Cooling: Kraken X62 for CPU, Corsair H55 with NZXT Kraken G12 for GPU
https://linustechtips.com/topic/800851-1050ti-wont-work/#findComment-10072005
https://linustechtips.com/topic/800851-1050ti-wont-work/#findComment-10073445
