Hello,
I currently have
i5 2500k OC to 4.3Ghz with a hyper 212x cooler
and
980ti G1 Gaming
I game at 4k mainly one a 60hz monitor. I usually get the frames i want so am happy with that. Getting extra frames would be nice too, i just dont want to lose any.
I also do video editing on it so going extra cores would help a lot too.
I am debating upgrading to a ryzen 5 1600. But this would cost me around $750 NZD to upgrade.
My other option is getting a cheap i7 2600 that i can overclok up to 4ghz. I know the non K skus dont go any higher no matter what.
Will i be losing frames do you reckon with this. Is it worth the upgrade?   Cost around $75 NZD
Or can find 2600k , Cost $150 NZD.
or maybe a ivy bridge i7 .. but will be more.  This is all in order to keep my z68 motherboard.
and yes i will be keeping a look out for other used hardware but  thats all thats available at this moment.
so to recap :
R5 1600 inc mobo and 16gb ram  = $750
i7 2600 = $75
i7 2600k = $150
Any advice would be awesome. Please back up opinions more than just because its newer or because its AMD / Intel
https://linustechtips.com/topic/800804-2500k-upgrade-help/
4 minutes ago, Flavlus said:
Hello,
I currently have
and
980ti G1 Gaming
so to recap :
i7 2600 = $75
i7 2600k = $150
the ryzen would be better than any of the intel upgrades you have mentioned. i seriously wouldnt bother buying another 2nd gen intel, save up and get a ryzen 1600.
https://linustechtips.com/topic/800804-2500k-upgrade-help/#findComment-10071484
Well I mean getting a 2600/k would save a lot of money, but R5 would be better by quite a lot. http://cpu.userbenchmark.com/Compare/Intel-Core-i7-2600-vs-AMD-Ryzen-5-1600/620vs3919. Have you thought about maybe selling your 2500k, ram, and mobo, that could help a bit.
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/800804-2500k-upgrade-help/#findComment-10071557
I would only get like 150 or so total
https://linustechtips.com/topic/800804-2500k-upgrade-help/#findComment-10071588
2 hours ago, Flavlus said:
-snip-
Well, if you were strictly gaming, the 2600K / 2700K is still a pretty viable choice, but no doubt the Ryzen is faster overall. It's just the high cost of DDR4 at the moment making it hard to justify a whole new platform.
I kind of went the cheap route and bought a 2700K for $130 USD last summer despite like a lot of people telling me to get a 7700K...and it multitasks and games well at 4.9 GHz OC. But since you're video editing / encoding / rendering, the six cores of the Ryzen would help a lot. If you were just gaming, I'd just say go with a used 2600K / 2700K (Or ivy bridge if you can find any deals...I couldn't. The 3770K still goes for $200+ for some reason...). And now my old 2500K just sits on my desk questioning life.
Definitely hard to judge for sure, no doubt the 2600K is the bang for the buck when overclocked, but overall the Ryzen would be considerably faster for multithreaded stuff.
https://linustechtips.com/topic/800804-2500k-upgrade-help/#findComment-10071866
How about a 6 core Xeon that'll fit your motherboard?
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/800804-2500k-upgrade-help/#findComment-10072407
I don't think the 2600 is worth it. I would get the i7 2600k if you want a cheap upgrade. It's also worth mentioning that your ram speed is also probably a bottleneck unless u have 2133mhz ddr3 kit.
So really this is all a question of time. If you want a fast upgrade then get the i7. If you have time to wait and save then get a modern platform.
https://linustechtips.com/topic/800804-2500k-upgrade-help/#findComment-10073830
58 minutes ago, Flavlus said:
I don't think that exists
Quite sure it does. I'll research Intel Ark after work.
Black Knight-
Daughter's Rig;
https://linustechtips.com/topic/800804-2500k-upgrade-help/#findComment-10074042
Bummer, I could have swore there were 6 cores. Couldn't find any though. You could get a 4C/8T Xeon E3-1240 v2 for $95.
Black Knight-
Daughter's Rig;
https://linustechtips.com/topic/800804-2500k-upgrade-help/#findComment-10074289
