I need help making this pc cheaper.
Go to solution Solved by TinyBolts,
2 minutes ago, deXxterlab97 said:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (€211.99 @ Amazon Deutschland)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  (€94.90 @ Amazon Deutschland)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  (€130.94 @ Mindfactory)
Storage: ADATA - Ultimate SU800 256GB 2.5" Solid State Drive  (€88.83 @ Mindfactory)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (€46.01 @ Amazon Deutschland)
Video Card: MSI - GeForce GTX 1080 8GB Video Card  (€556.99 @ Amazon Deutschland)
Case: Corsair - SPEC-ALPHA (Black/Yellow) ATX Mid Tower Case  (€72.89 @ Amazon Deutschland)
Power Supply: SeaSonic - 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  (€68.49 @ Amazon Deutschland)
Monitor: Asus - VC239H 23.0" 1920x1080 60Hz Monitor  (€146.99 @ Amazon Deutschland)
Keyboard: Ducky - Shine 4 Wired Gaming Keyboard  (€42.89 @ Amazon Deutschland)
Total: €1460.92
Generated by PCPartPicker 2017-06-30 11:45 CEST+0200
now its good, fits in my budget and could probably make the monitor 1440p
I need help with an AMD based pc that i will link here, i want it to get cheaper but I only have 1 idea, are these the same?
https://www.amazon.de/Prime-B350M-Mainboard-Sockel-Speicher/dp/B06WWF12J8/ref=sr_1_2?ie=UTF8&qid=1498812640&sr=8-2&keywords=am4
and
https://www.amazon.de/Prime-B350-PLUS-Mainboard-Sockel-Speicher/dp/B06X9LN311/ref=sr_1_4?ie=UTF8&qid=1498812640&sr=8-4&keywords=am4
also, here's the pc:
1. GPU - https://www.crowdfox.com/msi-gtx1080-gaming-x-8g-8192mb-pci-e-dvi-hdmi-3xdp-439761.html?pt=b989c17b&utm_source=idealo_network&utm_medium=PCE&utm_campaign=idealo_network&directCheckoutButton=true&petype=1&pesubtype=1&ttype=1 - EUR 562,99
2. CPU - https://www.amazon.de/dp/B06XNRQHG4/?tag=pcp05-21 - EUR 211,99
3. Mother - https://www.amazon.de/Gigabyte-GA-AB350-Gaming-GIGABYTE/dp/B06XMXVMCH/ref=sr_1_3?s=computers&ie=UTF8&qid=1498771822&sr=1-3&keywords=am4 - EUR 94,38
4. HDD - https://www.amazon.de/dp/B01LY65EVG/?tag=pcp05-21 - EUR 50,00
5. RAM - https://www.mindfactory.de/product_info.php/16GB-G-Skill-RipJaws-V-schwarz-DDR4-3200-DIMM-CL16-Dual-Kit_1013799.html - EUR 129,94
6. SSD - https://www.amazon.de/dp/B00P736UEU/ref=twister_B01K4Z5A5U?_encoding=UTF8&th=1 - EUR 92,69
7. CASE - https://www.amazon.de/Corsair-CC-9011083-WW-Spec-Alpha-Seitenfenster-PC-Gehäuse/dp/B01HUFNX4M/ref=sr_1_5?s=computers&ie=UTF8&qid=1498660129&sr=1-5&keywords=pc%2Bcase&th=1 - EUR 72,89
8. POWER - https://www.amazon.de/Corsair-CP-9020092-EU-RM750X-Modular-Netzteil/dp/B015Q7F4DO - EUR 116,89
9. MONITOR - https://www.amazon.de/AOC-G2460VQ6-Monitor-Reaktionszeit-DisplayPort/dp/B015510R4M/ref=sr_1_1?s=computers&ie=UTF8&qid=1498683970&sr=1-1&keywords=AOC+G2460VQ6 - EUR 148,01
10. COOLER - https://www.amazon.de/Cooler-Master-Hyper-CPU-Kühler-RR-212E-16PK-R1/dp/B0068OI7T8/ref=sr_1_1?ie=UTF8&qid=1498688140&sr=8-1&keywords=hyper+212+evo - EUR 28,90
11. KEYBOARD - https://www.amazon.de/Redragon-K502-Keyboard-Notbook-Computer/dp/B00LSGKEC4/ref=sr_1_fkmr0_1?s=computers&ie=UTF8&qid=1498736224&sr=1-1-fkmr0&keywords=Logitech+G105Redragon+K502 - EUR 34,90
https://linustechtips.com/topic/800767-i-need-help-making-this-pc-cheaper/
Could you use de.pcpartpicker instead please? The links are a mess.
The difference between those two motherboards is their form factor. One is ATX and the other is mATX.
It also makes very little sense to get a GTX 1080 for a 1080p 75Hz monitor. If you're looking to cut costs, lower your GPU to a GTX 1070.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
i want the pc to last a long time, of course, i could choose 1440p monitor
Then upgrade every few years or so. Buying a GTX 1080 for that monitor is a waste of money.
i wouldn't be able to upgrade for 3 years, or I can wait for Vega to come out and put one in here on black friday.
What about the 2 motherboards i linked? Does it matter which i pick?
RX Vega doesn't look promising (but I could be wrong).
If you're okay with lowering a few settings over time then the GTX 1070 will be more than fine. You are looking to lower the cost of the rig, no? You haven't said what your budget is.
13 minutes ago, TinyBolts said:
I don't know how to change countries in pcpartpicker.com and i don't know how to make a list with it. I'm new to all of this, maybe you could link a 1440p monitor in germany or so, would be nice.
https://de.pcpartpicker.com/
What is your budget for everything? I'll probably try and see what I can make.
An ATX mobo is naturally going to look nicer than a mATX one in a ATX case. But both of them are compatible.
budget is 1500
here
PCPartPicker part list: https://pcpartpicker.com/list/BdLxvV
Price breakdown by merchant: https://pcpartpicker.com/list/BdLxvV/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($199.99 @ SuperBiiz)
CPU Cooler: Cooler Master - Hyper T4 70.0 CFM Rifle Bearing CPU Cooler  ($22.76 @ NCIX US)
Motherboard: Asus - PRIME B350M-A Micro ATX AM4 Motherboard  ($87.46 @ B&H)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($135.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($104.33 @ OutletPC)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($42.49 @ Amazon)
Video Card: MSI - GeForce GTX 1080 8GB GAMING X 8G Video Card  ($724.89 @ OutletPC)
Case: Corsair - SPEC-ALPHA (Black/Yellow) ATX Mid Tower Case  ($79.99 @ Amazon)
Power Supply: Corsair - RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Amazon)
Monitor: AOC - G2460VQ6 24.0" 1920x1080 60Hz Monitor  ($169.99 @ B&H)
Total: $1667.88
Generated by PCPartPicker 2017-06-30 05:32 EDT-0400
PcPartPicker is wrong, if I add everything together from my list i get EUR 1536, so i just need to make it a bit lower.
here
Total: $1667.88
Use http://de.pcpartpicker.com
You don't need a cooler, there are propably cheaper 1070, a 550w is fine for a GTX 1070 and there are cheaper SSD that performs as decent as well.
Because you're not using the German one.
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-2800 Memory  (€117.99 @ Amazon Deutschland)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  (€92.71 @ Amazon Deutschland)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€50.58 @ Amazon Deutschland)
Case: BitFenix - Nova ATX Mid Tower Case  (€34.90 @ Caseking)
Power Supply: Corsair - Vengeance 500W 80+ Bronze Certified ATX Power Supply  (€63.34 @ Amazon Deutschland)
Monitor: AOC - G2460FQ 24.0" 1920x1080 144Hz Monitor  (€245.81 @ Amazon Deutschland)
Total: €1512.10
Generated by PCPartPicker 2017-06-30 11:37 CEST+0200
I would go with the Ryzen 5 1500x since I've heard 1600 has some stability issues because of the 6 core/12 threads thingy. It'll also lower your price a bit.
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
Total: €1460.92
Total: €1460.92
I know it is in usd, and prices can vary by country. I also noticed you didn't include a mouse, but this is what i threw together based on your parts list. With a budget of €1500.00 or $1711.00 at time of typing, I created this list.
amd.pdf
amd.pdf
i have a mouse
amd.pdf
the build seems nice :3, im now searching for the stuff on idealio
