Sleeved Cables ~ Corsair
Solved by STRMfrmXMN,
6 minutes ago, Siq said:I recently bought a Corsair HX750 750w PSU, and some Phanteks Sleeved Cables with a dumbfounded assumption that they would fit into my PSU. I was wrong (lmao).
I see that some of cablemods choices cover HXi PSU's and such, but I'm curious to if anybody knows of any cables that would be a definite fit for the PSU I bought.
I really onl'y want visible cables such as 24pin, 6+2 pins, and the CPU pin.
Thank you!
Those are extensions you bought. Of course they don't plug right into the PSU, they plug into the existing cables to, ya know, extend.
