I have played bf1 since launch and never had too many issues with it. There was some lag and stutter, but never anything too serious, but now the game is near unplayable on every map, all settings, etc. Is this because of a jenk update or what?
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/800020-bf1-issues/
Open up MSI Afterburner's OSD and see what component is acting up. Make sure that you show each CPU core's usage.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063491
thats what it looks like after a game https://gyazo.com/d4b380b9f455a7bd3b568628069d45ff
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063636
And the GPU? RAM? Pagefile?
All I can tell you from that is that your CPU is working as hard as it can. And that diagnosis isn't complete nor good to any stretch of the imagination as it's the only thing I've been shown.
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063675
Besides the CPU everything is running stable, no strange dips or anything, and my PC runs all other gmes perfectly fine
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063712
Are you running V-Sync? If you aren't, use it and test again.
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063717
Im using adaptive vsync through the control panel which is the only thing keeping the game semi-playable. The ingame vsync gives me insane input lag and lag in general, and no vsync gives horrible lag even with over 60fps
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063726
What's the usage on the 970? Is it capped out at 100%?
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063738
no it doesnt cap out its around 80-90% or smthn but id have to play another game to be 100% accurate about it
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063744
Seems like upping the CPU frequency will help you out and you can try increasing detail or scaling for the GPU.
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063751
you mean overclock my cpu because im not really comfortable trying that
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063755
Overclocking is relatively easy and it'll buy you some time if you want to buy a 4790K.
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063767
i wont be buying a new cpu until i absolutely have to cause im broke, but I just dont want to OC because the cpu already runs hot as fuck + i dont want to break it
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063776
Then I would start increasing the resolution scaling in the game so that the GPU is working harder.
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063782
Thanks for the help. Ive tried messing with the scaling alot already though and it only makes me lag even harder. I have undoubtedly more hours trying to fix this moneygrab of a game than actually playing it so I guess Im gonna uninstall
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063823
What are your CPU temps? You can safely go to 85C. Open another topic for help with overclocking or take a look at some of the forum guides that are already available.
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063832
they hit like 65 max while playing bf1, ill try it one of these days i guess but alot of places ive read say that there is just issues between haswell CPUs/i5/i3 CPUs and Bf1 in general for whatever reason
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063849
It likes threads and frequency equally as much. I'd get the i7-4770K if this isn't the only game you play that would benefit.
https://linustechtips.com/topic/800020-bf1-issues/#findComment-10063869
