2 minutes ago, SCGazelle said:
capturing is 1440p144hz playing Overwatch.
Thats an insane demand on the CPU and GPU
You should lower the recording resolution to 1080p and bit rate to around 8,000 or higher but probably not more than 12,000
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/799628-frame-drop-in-obs/#findComment-10059118
Alright few issues. I don't think you understand, there is a reason youtubers record in 1080p60 and even then that is so far and few between. Most record in just 720p/1080p 30 though some will do 720p60. You don't need to produce such high quality content, especially if you don't even have a big audience. People won't mind 1080p60FPS or 720p 60FPS, if you are naturally good at commentatingand providing good content they'll look over that. Also streaming in the quality present is not something I suggest, Balanced is a far better and more optimized option. I highly suggest changing output resolution to 720p or 1080p.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/799628-frame-drop-in-obs/#findComment-10059139
thanks for the feedback. I was hoping there would be some way to allocate a little more performance or optimize obs a little more. I am getting 200+ fps in overwatch. I rarely see me go below 180fps so I thought I could record at native res. Anyways. I lowered resolution to 1080p and I never see OBS drop frames so problem solved I guess.
https://linustechtips.com/topic/799628-frame-drop-in-obs/#findComment-10059253
