Pre-outs help?
Go to solution Solved by johnt,
1 minute ago, cheese1 said:
So, im very very new to home audio, and im building a home theater soon, and im gonna need multiple power amps, is there any way to be able to control all the volume knobs at once? or would i still control that from the volume knob on my 11.2 receiver even though its using the pre-outs?
Is this for your car to annoy your neighbors?
You will be able to use the volume knob on your receiver when using pre-outs. The receiver will act like a pre/processor or pre-amplifier. Amplifiers don't typically have a volume adjustment. Maybe a sensitivity switch, but those aren't common either.
https://linustechtips.com/topic/799534-pre-outs-help/
https://linustechtips.com/topic/799534-pre-outs-help/#findComment-10058009
no its for my room for music "yeah i know, 10 15's and 4 (or 8, im not sure yet) 18 inch subs) and i know music isn't surround, but im gonna convert the music to 11.2... and yes its also to annoy my neighbors LOL
https://linustechtips.com/topic/799534-pre-outs-help/#findComment-10058032
Ha... yeah music is usually two channel, but you can use built-in DSP to route the signal to the other speakers. I listen to multi-channel output all the time. It sounds good!
https://linustechtips.com/topic/799534-pre-outs-help/#findComment-10058043
