HDD - unpleasant noise
Solved by InertiaSelling,
There was vibration because the drive bay made full contact with the case in its default location. I mounted it a bit higher using some dampening screws from an old workstation, and it stayed silent.
I even added a 2.5" laptop HDD in an SSD bracket just for fun, but even that did not make it any louder.
Problem solved, thanks for your answers @ARikozuM @Jack Kaye Pc Gamer
