gtx 1070 might not run 1440p games at high settings 3-4 years later.
no hard disk?
B350 mobo is better. SLI support is not worth it since multi-GPU itself is not a good way to spend money
Desktop benching:
https://linustechtips.com/topic/798457-pc-build-advice-pls/#findComment-10046343
Add a 1tb blue caviar HDD, but good luck finding a 1070 with this whole eth mining craze.
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/798457-pc-build-advice-pls/#findComment-10046352
Yes i do intend on getting a hdd must have forgotten in the plan and yea the budget gpu market is getting pretty dry cuz of bitcoin mining.
https://linustechtips.com/topic/798457-pc-build-advice-pls/#findComment-10046356
Yea, also it's not bitcoin, its etheruem btw ;)
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/798457-pc-build-advice-pls/#findComment-10046359
isn't it pretty much the same thing?
They're both digital currencies, but eth seems to be way more popular atm, and is causing all GPU's under a 1080 to go out of stock and sell for 200 dollars more on ebay :)
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/798457-pc-build-advice-pls/#findComment-10046370
I made two small changes. The ssd wasn't very good and you were paying way too much for it and a higher wattage version of the same psu was available for cheaper so I switched those.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($199.99 @ SuperBiiz)
Motherboard: Asus - PRIME X370-PRO ATX AM4 Motherboard  ($149.99 @ Amazon)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3200 Memory  ($159.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($77.99 @ SuperBiiz)
Video Card: MSI - GeForce GTX 1070 8GB Video Card
Case: Phanteks - ECLIPSE P400 ATX Mid Tower Case  ($69.99 @ Amazon)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ Newegg)
Monitor: Acer - G257HU smidpx 25.0" 2560x1440 60Hz Monitor  ($261.80 @ B&H)
Total: $989.74
Generated by PCPartPicker 2017-06-25 11:38 EDT-0400
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/798457-pc-build-advice-pls/#findComment-10046517
Total: $989.74
Thanks man appreciate your help.
https://linustechtips.com/topic/798457-pc-build-advice-pls/#findComment-10047329
