Hi,
I bought my H100i 2 months ago. At the time i selected a random collor change for the H100i. Since i bougt some cold cathodes to "show" my rig. But my old collorsceme does not match the new collors. I wanted to change the collors in Corsair Link (v2.45) but i saw that it didn't detect my H100i nor the LED. But it does detect my HDD's, my CPU and my GPU.
I went on the interent to find some anwers but everyting i found and tried failed. Even this (http://forum.corsair.com/forums/showthread.php?t=118373)...
Can someone please help me?
Thanks
https://linustechtips.com/topic/79818-h100i-problems/
have you plugged everything in?
CPU: i7-4770k @stock  GPU: Gigabyte Windforce GTX 780ti OC  MotherBoard: Gigabyte GA-Z87X-UD4H  RAM: Corsair Vengeance Pro (1600 MHz, 2x8GB)
CPU Cooler: Stock Cooler  Storage: Samsung 840 Pro 2x256gb(OS/Games), 1TB Seagate Barracuda(storage)  PSU: Corsair AX860i
Case: Corsair Obsidian 750D Mouse: Roccat Kone XTD Keyboard: Corsair Vengeance K70
https://linustechtips.com/topic/79818-h100i-problems/#findComment-1094576
He has a point^^^^^^^, just check
<p> AMD FX-8350 CPU, Asus M5A99FX PRO R2.0 Mobo, Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1866 Memory,Samsung 840evo 120gb ssd, Samsung 840evo 256gb ssd, Western Digital Caviar Blue 1TB HDD, Gigabyte Radeon R9 270X 2GB Graphics card, Fractal Design Define R4 w/Window (Black Pearl) Case, Corsair CS 750W 80+ Gold PSU, Windows 7 Home Premium
https://linustechtips.com/topic/79818-h100i-problems/#findComment-1098667
I plugged everything in. The 3pin, the sata for power, the USB and the fans. But it still wont regeister the H100i, or any of the fans...
First i tougth the USB cable din't work but if i take it out it makes the USB disconected sound...
Anyone has the same problem or an answer?
https://linustechtips.com/topic/79818-h100i-problems/#findComment-1105093
