https://pcpartpicker.com/list/2gJ8cc
My budget is $2,700~ (USA) with the aim being 4k Gaming and occasionally watching video
This is my first planned build so I am very new. My monitor is a 4k UHD TV which I plan to hook up using HDMI 2.0
Any feedback or revisions would be appreciated!
https://linustechtips.com/topic/797886-first-desktop-build/
get an air cooler, less troubles and more powerful (at least than the aio that you have chosen), such as noctua nh-d15 and less noisy
10tb of storage for what, p***?, well, you should get 500gb ssd for games and other 5tb max for whatever you need to storage there but 10tb is an overkill, even for 4k video storage
i'd get windows 10 for 30$ on kinguin
did you know that your case does not have price no?
and psu is an overkill, no 1k watt needed but yes if you want a full silent psu
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/797886-first-desktop-build/#findComment-10041392
To be more specific for the case, it is $160 as well as the Airflow version.
As for the other stuff, thanks for the revisions.
https://linustechtips.com/topic/797886-first-desktop-build/#findComment-10041399
  1. Since you are just gaming and watching 4K movies you won't need more than 16GB, invest it elsewhere it's easy to upgrade.
  2. For a single 1080ti, 650Ws will more than suffice.
  3. Get a bigger SSD and a smaller hard drive, you don't really need 10TB for 4K movies to be honest. 4TB will suffice.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/797886-first-desktop-build/#findComment-10041400
Just now, Castdeath97 said:
  1.
but if he/she wants a silent psu?
https://linustechtips.com/topic/797886-first-desktop-build/#findComment-10041403
I want 1000Ws because I plan on getting another 1080ti in the future for SLI. Silence is good as well.
https://linustechtips.com/topic/797886-first-desktop-build/#findComment-10041408
Agree with the bigger ssd/ smaller storge drive/less ram.
Nothing wrong with an overpowered PSU. A good quality PSU will last for a while, and it is pain to have to upgrade down the road if you end up with a higher power requirement.
That is a pretty large case. Could go with something a bit smaller with that build.
https://linustechtips.com/topic/797886-first-desktop-build/#findComment-10041409
well, even for 2 1080ti you would not need that much power but if you have enough money for less noise, go for it
https://linustechtips.com/topic/797886-first-desktop-build/#findComment-10041411
PCPartPicker part list: https://pcpartpicker.com/list/Hk9Jd6
Price breakdown by merchant: https://pcpartpicker.com/list/Hk9Jd6/by_merchant/
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor  ($326.49 @ OutletPC)
CPU Cooler: Noctua - NH-D15 82.5 CFM CPU Cooler  ($88.15 @ Amazon)
Motherboard: Asus - STRIX Z270-E GAMING ATX LGA1151 Motherboard  ($199.00 @ B&H)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive  ($174.58 @ B&H)
Storage: Seagate - BarraCuda 4TB 3.5" 5400RPM Internal Hard Drive  ($114.00 @ Amazon)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB FTW3 GAMING iCX Video Card  ($778.99 @ SuperBiiz)
Case: Corsair - Obsidian Series 800D ATX Full Tower Case
Power Supply: EVGA - SuperNOVA G3 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($144.99 @ SuperBiiz)
Optical Drive: Asus - DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($18.69 @ OutletPC)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($89.89 @ OutletPC)
Total: $2048.78
Generated by PCPartPicker 2017-06-24 05:16 EDT-0400
@deXxterlab97
https://linustechtips.com/topic/797886-first-desktop-build/#findComment-10041413
PCPartPicker part list: https://pcpartpicker.com/list/cDZRtJ
Price breakdown by merchant: https://pcpartpicker.com/list/cDZRtJ/by_merchant/
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($294.49 @ SuperBiiz)
CPU Cooler: Noctua - NH-D15 SE-AM4 140.2 CFM CPU Cooler  ($89.90 @ Amazon)
Motherboard: Gigabyte - GA-AB350-GAMING 3 ATX AM4 Motherboard  ($93.98 @ Newegg)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($126.99 @ Amazon)
Storage: Samsung - 960 PRO 512GB M.2-2280 Solid State Drive  ($324.31 @ Amazon)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB SC Black Edition Video Card  ($719.99 @ B&H)
Case: Fractal Design - Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($119.89 @ OutletPC)
Power Supply: SeaSonic - PRIME Titanium 750W 80+ Titanium Certified Fully-Modular ATX Power Supply  ($166.69 @ SuperBiiz)
Operating System: Microsoft - Windows 8.1 Pro OEM 64-bit  ($79.98 @ My Choice Software) *cheaper and can still upgrade to 10 for free.
Total: $2034.91
Generated by PCPartPicker 2017-06-24 05:25 EDT-0400
https://linustechtips.com/topic/797886-first-desktop-build/#findComment-10041434
PCPartPicker part list: https://pcpartpicker.com/list/wKXPkT
Price breakdown by merchant: https://pcpartpicker.com/list/wKXPkT/by_merchant/
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($106.99 @ Amazon) Better AIO, the H50 isn't that great.
Motherboard: MSI - Z270 GAMING PRO CARBON ATX LGA1151 Motherboard  ($131.98 @ Newegg) Cheaper, and still has RGB and SLI support.
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($135.89 @ OutletPC) You wont need 32 GB for gaming or watching videos.
Storage: Samsung - 850 EVO-Series 1TB 2.5" Solid State Drive  ($339.99 @ Amazon) Better SSD, and much more capacity.
Storage: Western Digital - Gold 4TB 3.5" 7200RPM Internal Hard Drive  ($181.99 @ SuperBiiz) Do you really need 10 TB? If you do, feel free to get the 10 TB drive.
Case Fan: Corsair - HD120 RGB 3-Pack w/Controller 54.4 CFM  120mm Fans  ($79.75 @ OutletPC) Replace the stock corsair fans on the H100i with these, the stock ones are pretty loud. You can save some money, if you get the SP version, which just has less modes, or just get the SP non RGB version, if you don't care for lighting.
Total: $2595.14
Generated by PCPartPicker 2017-06-24 05:22 EDT-0400
https://linustechtips.com/topic/797886-first-desktop-build/#findComment-10041438
CPU Cooler: be quiet! - Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($83.78 @ OutletPC)
Motherboard: ASRock - X370 KILLER SLI/ac ATX AM4 Motherboard  ($138.98 @ Newegg)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($114.99 @ Newegg)
Storage: SK hynix - SL308 500GB 2.5" Solid State Drive  ($145.89 @ OutletPC)
Storage: Toshiba - X300 4TB 3.5" 7200RPM Internal Hard Drive  ($115.99 @ Amazon)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB Gaming OC 11G  Video Card (2-Way SLI)  ($704.98 @ Newegg)
Case: Phanteks - Enthoo Pro M Tempered Glass ATX Mid Tower Case  ($107.98 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($109.99 @ Newegg)
Total: $2630.63
Generated by PCPartPicker 2017-06-24 05:28 EDT-0400
https://linustechtips.com/topic/797886-first-desktop-build/#findComment-10041439
I would go for a Ryzen build.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($199.99 @ SuperBiiz)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.88 @ OutletPC)
Motherboard: Gigabyte - GA-AX370-Gaming K5 ATX AM4 Motherboard  ($151.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($119.99 @ Newegg)
Storage: Crucial - MX300 525GB 2.5" Solid State Drive  ($150.91 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($66.89 @ OutletPC)
Case: Cooler Master - MasterBox 5 (Black) ATX Mid Tower Case  ($59.99 @ SuperBiiz)
Total: $2394.47
Generated by PCPartPicker 2017-06-24 05:46 EDT-0400
https://linustechtips.com/topic/797886-first-desktop-build/#findComment-10041471
The overkill egend!
[PCPartPicker part list](https://pcpartpicker.com/list/BVyX7h) / [Price breakdown by merchant](https://pcpartpicker.com/list/BVyX7h/by_merchant/)
Type|Item|Price
**CPU** | [AMD - Ryzen 7 1700X 3.4GHz 8-Core Processor](https://pcpartpicker.com/product/9Q98TW/amd-ryzen-7-1700x-34ghz-8-core-processor-yd170xbcaewof) | $348.45 @ OutletPC
**CPU Cooler** | [Noctua - NH-D15 SE-AM4 140.2 CFM CPU Cooler](https://pcpartpicker.com/product/shNypg/noctua-nh-d15-se-am4-1402-cfm-cpu-cooler-nh-d15-se-am4) | $89.90 @ Amazon
**Motherboard** | [Asus - CROSSHAIR VI HERO ATX AM4 Motherboard](https://pcpartpicker.com/product/gj7CmG/asus-crosshair-vi-hero-atx-am4-motherboard-crosshair-vi-hero) | $236.99 @ SuperBiiz
**Memory** | [Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory](https://pcpartpicker.com/product/p6RFf7/corsair-memory-cmk16gx4m2b3200c16) | $135.99 @ Amazon
**Storage** | [Samsung - 960 Pro 1.0TB M.2-2280 Solid State Drive](https://pcpartpicker.com/product/C3mxFT/samsung-960-pro-10tb-m2-2280-solid-state-drive-mz-v6p1t0bw) | $599.49 @ Amazon
**Video Card** | [EVGA - GeForce GTX 1080 8GB FTW2 Gaming iCX Video Card](https://pcpartpicker.com/product/fGDzK8/evga-geforce-gtx-1080-8gb-ftw2-gaming-icx-video-card-08g-p4-6686-kr) (2-Way SLI) | $549.98 @ Newegg
**Case** | [Fractal Design - Define S w/Window ATX Mid Tower Case](https://pcpartpicker.com/product/yLDzK8/fractal-design-case-fdcadefsbkw) | $74.99 @ Newegg
**Power Supply** | [SeaSonic - 750W 80+ Gold Certified Fully-Modular ATX Power Supply](https://pcpartpicker.com/product/9RZQzy/seasonic-power-supply-ss750km3) | $107.89 @ Newegg
 | *Prices include shipping, taxes, rebates, and discounts* |
 | Total (before mail-in rebates) | $2743.66
 | Mail-in rebates | -$50.00
 | **Total** | **$2693.66**
 | Generated by [PCPartPicker](http://pcpartpicker.com) 2017-06-24 09:15 EDT-0400 |
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
https://linustechtips.com/topic/797886-first-desktop-build/#findComment-10041802
