Just now, TheGhzGuy said:
1. Personally, I recommend a wired connection if you can get it
2. What do you mean by "cheap"?
I would like one too but I would need to run a ethernet underneath our house and we are moving soon so.. its not worth the effort. By cheap I mean a adapter that wont fall apart on me and can do those speeds at the least amount of money.
Well, there's an Edimax branded one you can buy for 7.99 on Amazon. Unfortunately, I don't have it with me at the moment, but it has a few thousand reviews so it should be alright. That one can't do AC WiFi however.
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
What is AC WiFi?
Just now, TheRedEyedTerror said:
What is AC WiFi?
AC wifi is a standard of WiFi that uses the 5GHz band. All others that I know of (Minus AD, but don't worry about that one) use 2.4GHz bands. Basically, AC is meant to be faster and less crowded than all those other standards of WiFi.
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
Ok I think im on 2.4GHz, can you link me to the card you recommenced?
Would you prefer a PCI-e card or a USB dongle?
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
1 minute ago, TheRedEyedTerror said:
I would prefer PCl-e with a USB dongle i  would probably break it off.
Usually the USB ones are tiny anyway, but I'll find a PCI-e one for you.
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
