I just bought a Seasonic X-650 power supply. My old (crap) power supply has a voltage switch to suit different voltages in different countries, but this unit doesnt have one. Instead, it just says "Input Voltage: 100-240VAC". Checked the user manual, and there's nothing about input voltage. Should I just plug everything in as if it automatically adapts to the input? The voltage here is 220V AC btw.
Desktop benching:
https://linustechtips.com/topic/795957-input-voltage-switch/
Your older PSU was exactly that, older, thus requiring the manual switch. However, newer PSUs switch automatically, so you can plug it in and it'll be fine.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/795957-input-voltage-switch/#findComment-10019920
exactly.
if it says 100-240 volts on the sticker it MEANS 100-240 volts.
https://linustechtips.com/topic/795957-input-voltage-switch/#findComment-10019966
Your PSU switches automatically like any decent PSU made within the last 5 years.
https://linustechtips.com/topic/795957-input-voltage-switch/#findComment-10021431
