Hi guys.I am new to PC building and I have encountered some problems regarding where to put the wires.I dont understand the manual,hope someone can help me out here.Below is the picture of my motherboard and the wire that I have no clue putting it on.
Motherboard MSI B350M mortar
PSU:Masterwatt 600W
Case:CoolerMaster K350
Thanks
https://linustechtips.com/topic/795852-need-help-in-some-cables/
12 minutes ago, Oshino Shinobu said:
That connector goes on the top row on one of the USB headers on the motherboard. Line up the blanked off pin with the blanked pin on the board header.
Is it the top row of the 1st picture and the last four pins on the right side that i connect it to?Thanks
3 minutes ago, Bqtacke222 said:
Is it the top row of the 1st picture and the last four pins that i connect it to?Thanks
It will be a header like this, they will have something like "JUSB" next to it. Look for the blanked off pin and line the connector up with it.
main-qimg-460ff591757de5b1fb42b21e8b4ffd
I have both ports,may I know which ports to use though.So i just pluck into the last row with the 4 pins 1 with 1 empty slot?
yes
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
