So I'm stuck on whether I want a beast 1500 dollar pc or maybe lower the specs and get a gaming chair that is around 300 dollars. I want my pc to definitely have a zotac 1080 and in a corsair 460x rgb. With that in mind I sit in a pretty uncomfortable chair wich ruined my last pc experience wich was a 1070 i5 6600k build until I sold it because someone offered me more money than it was worth simply because it was built. But if you guys have any words of wisdom or can help me with my dilema I would appreciate it very much. Ps. I have a 1080 p asus monitor and keyboard/mouse
https://linustechtips.com/topic/795275-stuck-building-my-1500-setup/
I'd bail on some spec and get a good comfortable chair, back problems and discomfort or pain will soon haunt you if you plan to sit on it for an extended period of time. After sitting on a bad chair for the last year (I switched to an office chair later) I still get pain when I move my left shoulder occasionally
You could get a PC and a chair but you don't have to pay 300$ for one. There are cheeper options which are very comfortable as well. And the word gaming in the name doesn't make the chair better. I went to a real store and tried out different chairs and got a nice one which was on sale.
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
On 2017-6-19 at 1:05 AM, Nvmeisfuture said:
I want my pc to definitely have a zotac 1080.  I have a 1080 p monitor
That's just stupid. Spend some of your budget on a better monitor, and still get a GPU capable of running the monitor.
get a gaming chair that is around 300 dollars.80 p asus monitor and keyboard/mouse
Also a bad idea. You can easily get a perfectly good chair for <$150, instead of just wasting money for "gaming chair". That would also give you more money for your system.
27 minutes ago, openthatchest said:
get 2 RX 580's
That's stupid. He should be getting the best single GPU he can.
OP;
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($195.69 @ SuperBiiz)
Motherboard: MSI - X370 SLI PLUS ATX AM4 Motherboard  ($131.99 @ Amazon)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($114.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($99.99 @ B&H)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.44 @ OutletPC)
Video Card: Asus - GeForce GTX 1070 8GB STRIX Video Card  ($449.99 @ NCIX US)
Case: Phanteks - ECLIPSE P400S TEMPERED GLASS ATX Mid Tower Case  ($89.98 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($119.69 @ SuperBiiz)
Monitor: Dell - S2417DG 23.8" 2560x1440 165Hz Monitor  ($361.56 @ Amazon)
Total: $1612.32
You still have around $200 left for a nice chair, more than enough. You get a nice new monitor. 1440p, G-Sync, 165Hz. Now, a GTX 1070 isn't quite enough to run AAA titles maxed out at 1440p 165Hz. However, G-Sync will make it a great experience regardless. For more demanding titles, you can just lower settings if you want to achiever higher FPS, or settle for lower FPS with better settings. You could always add a 2nd GTX 1070 later since you have SLI support. Or, you could upgrade to a 1080Ti, and still have SLI support with that. SLI GTX 1070 or a GTX 1080Ti would handle 1440p 165Hz perfectly.
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
