Hi all, I was wondering if you could help me out with this. I am planning to do a pc build, but I am not exactly sure if everything is compatible. Please go easy on me, as this is my first time building a PC. ;)
CPU: Intel Core I5-7600K
GPU: Radeon RX 580 8 GB
RAM: 16 GB, DDR 4, 2133 MHz
HDD: 1 up to 2 TB at 7200 RPM
Optical Drive: ASUS 24D5MT
PSU: Cooler Master B600
Motherboard: ASUS Prime B250 Plus
CPU Cooler: Cooler Master Hyper 212 EVO
Case: Sharkoon VG5-V
The next assets are not included in the $1100
Monitor :AOC G2460VQ6 24''
Mouse and keyboard: Whatever gets the job done
I do not want to overclock the system, hence I do not really care if it is possible.
If I looked over something or if anything is not compatible, please tell me what I can do to make the system work, knowledge is power!
https://linustechtips.com/topic/795142-first-pc-build/
Throw away Intel, get AMD Ryzen 5 1600.
Where do you live?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/795142-first-pc-build/#findComment-10010130
Just now, SirShredder said:
Hi JDE, I live in The Netherlands.
I am a bit of a dummy if it is about AMD, what Intel CPU can we compare the Ryzen 5 1600 with?
1. Please press the quote button when replying. We get a notification when you do, but if you don't, we may not respond.
2. In gaming, around the i5 7600K. In multithreaded loads, around the i7 5820K/6800K
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/795142-first-pc-build/#findComment-10010149
Get an R5 1600 and this ram kit https://www.gskill.com/en/product/f4-3200c14d-16gfx
An Intel CPU will have a bit better IPC, but fewer cores. One of my mates went R7 1700 and he had an i7 4790k, he reported slightly higher FPS and better frame timings.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/795142-first-pc-build/#findComment-10010155
Alright, got it. This got me wondering, how can the Ryzen be at the same performance level as the I5-7600K, even though it's frequency (MHz)is  lower?
https://linustechtips.com/topic/795142-first-pc-build/#findComment-10010157
Also, is there a link where we can search prices?
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/795142-first-pc-build/#findComment-10010158
6 cores. 12 threads. vs the i5 4 cores 4 threads. Kaby Lake has better IPC though, so you will get slightly higher performance in games with the i5, but the R5 will crush the i5 when doing multithreaded tasks.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/795142-first-pc-build/#findComment-10010164
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/795142-first-pc-build/#findComment-10010204
https://linustechtips.com/topic/795142-first-pc-build/#findComment-10010264
8 hours ago, SirShredder said:
I see where you are going, but I do actually prefer HDD's over SSD's, and I think I am comfortable with the Sharkoon case. The GTX 1060 6 GB might indeed be the better choice here.
by the way, I see you managed to get around on the website, well done! ;)
I can guess Dutch ;)
Anyways, SSD improves boot times a lot. Get that, then add an HDD later. They are cheap.
EDIT: Also I included the 1060 over the 580 because it was out of stock, just like the rest of the world.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/795142-first-pc-build/#findComment-10012638
