Hard drive only recognized after reseating sata cable
Solved by Mobrockers,
If anyone comes across the same issue in the future, don't be dumb like me and buy a new hard drive and sata cables before you check the sata ribbon cables are still properly seated in your modular power supply..
Today realized my psu is modular, so the ribbon cable needs to be plugged in to the psu.. And I never checked if it properly was.
And yea, it wasn't. So that's most likely why this weird issue kept happening randomly while the drives all seemed fine. My psu is semi-modular so all other components were functioning perfectly fine.. Only my hard drives were not getting enough power. My boot drive is an ssd which I guess uses less power so did not have any issues.
