I have been looking for a case for my new build, cant decide on what i want, im looking for a mid tower with an open interior in which will be very flexible, and i want a simplistic design on the outside of the case, i wont be needing any 5.25 drive bays and wont need many hdd slots. The case i have now is the corsair carbide 500r and i dont like it to much, for reasons such as you can see the drive cages, there is no side panel window, it isnt very flexible with water cooling and the interior has too many drive slots. I will be running with a 1080 ti and either i5 or i7 kabylake that will be watercooled in my new case, ive been looking at the phanteks p400s but want to know if there is any other case that would better fit my needs.  Im going with a red and black build so a case with this color scheme would best work otherwise i would probably wrap it with vinyl colored wrap. Money and space is not an issue. Any suggestions are appreciated thanks. :)
https://linustechtips.com/topic/794293-help-deciding-on-a-case/
Thermaltake has a couple they are water cooling freindly and have a side panel window but they do have some drive bays
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/794293-help-deciding-on-a-case/#findComment-10001201
No optical drive? Xanthe sad. Optical drives are cool. :(
Yes, it's 2871 as in the year 2871. I traveled all this way, back in time, just to help you. And you thought your mama lied when she said you were special-_-
https://linustechtips.com/topic/794293-help-deciding-on-a-case/#findComment-10001202
1 minute ago, 107x said:
masterbox or mastercase? ive never heard of masterbox
It's a budget friendly and clean case
https://linustechtips.com/topic/794293-help-deciding-on-a-case/#findComment-10001204
4 minutes ago, Vespertine said:
MasterBox, sure you can go for MasterCase if you want to waste money.
i think the mastercase is definetly more watercase friendly with the pop up top and front,
what about the phanteks p400s ?
https://linustechtips.com/topic/794293-help-deciding-on-a-case/#findComment-10001249
5 minutes ago, 107x said:
yeah, xD i got sick of them, especially having 4 of them that ive never used in my current case.
But, you could have two drives and two cool adapters that add functionality to your case, like these:
Image result for 5.25 bay card reader
Image result for 5.25 bay screen
Image result for 5.25 bay drawer
Image result for 5.25 bay ports
Image result for 5.25 bay fan
You get the idea...
https://linustechtips.com/topic/794293-help-deciding-on-a-case/#findComment-10001252
Personally I don't care for the minimalist cases, I think a computer should be covered in buttons and ports and fans and other cool stuff, but if you like that kind of design the case you choose looks pretty cool, I suppose. :D
https://linustechtips.com/topic/794293-help-deciding-on-a-case/#findComment-10001265
From what I've heard from the P400S it is horrible for water cooling temps
https://linustechtips.com/topic/794293-help-deciding-on-a-case/#findComment-10001269
haha yeah idk not really me lmao thanks for the suggestion i think i have my mind set on a few cases now
https://linustechtips.com/topic/794293-help-deciding-on-a-case/#findComment-10001272
