I woke up this morning to no display on my PC. I was working last night just fine.
When I boot, the fans spin, lights come on, but there's no display; the monitor doesn't wake up. My keyboard and mouse backlights don't come on either. The first thing I tried was pulling the GPU and network card, and connected the monitor to the iGPU. Same deal. I then removed the RAM, which caused a boot loop. I tried one stick, and it booted and my keyboard backlight came on, but no display, no POST. I tried the other stick alone, and no backlight, no display, no POST. I didn't have time to do anything else before I had to head to work. I don't have any extra gear, so I can't trade out things to test.
Any ideas as to what else I can do to test this?
Here's my rig: https://pcpartpicker.com/list/HQxZ3F
Thanks in advance for any help.
https://linustechtips.com/topic/794170-pc-wont-post-no-display/
reset cmos is always a good idea when you cant think of anything, its worked for me at least once
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/794170-pc-wont-post-no-display/#findComment-9999795
Didn't have a jumper, so I pulled the battery and power from the wall for about a minute. Still no POST from iGPU, one RAM stick in slot 2. Should I try putting my GPU back in? Also, I've unplugged all my storage drives from the motherboard, but they're still getting power. Would pulling their power make a difference?
I swapped the RAM sticks I had and now it wakes up the keyboard, but still no display.
https://linustechtips.com/topic/794170-pc-wont-post-no-display/#findComment-10001695
Last ditch efforts today included pulling all connections from motherboard and power supply, leaving just PSU, CPU, and one RAM stick installed, with motherboard, CPU, and three fans on the power. Pulled the battery and wall socket for 10 minutes, and nothing. Swapped the RAM to another module, it boot-looped once, then stayed on, no post, no display.
https://linustechtips.com/topic/794170-pc-wont-post-no-display/#findComment-10008827
