My Evolv ITX SIDE panel is scratched up.planning to get a new case with tempered glass and support for full size PSU.
any recommendations?
Ryzen  5 3600 | ASUS Strix B450i Strix | G-Skill Trident Z RGB 16gb 3200mhz
Gigabyte RTX 2070 Super OC | Samsung 970 EVO Plus 500gb | NZXT H200i | NZXT x52 | Corsair RM650x
https://linustechtips.com/topic/793488-itx-tg-recommendation/
Why not fix the side panel? Mod a window, paint the case, or something?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/793488-itx-tg-recommendation/#findComment-9992349
Yes, I found a local glass hardware, i researching on how could I mount it nicely. but still if it doesn't work i need some other plans.
https://linustechtips.com/topic/793488-itx-tg-recommendation/#findComment-9992461
The Enthoo is the only one that I know of.
https://linustechtips.com/topic/793488-itx-tg-recommendation/#findComment-9992464
