My mother was using her PC, when the power went out. When it came back on the PC BSOD and gave the error "Critical process died". It said going into recovery, but never did. So I took out her SSD and put it into my PC. The drive still worked. So I tried to see if I could fix it, but I can't figure out how. I think I have to reinstall windows, but every time I try it says "the drive is locked" How do I fix this?
https://linustechtips.com/topic/793360-critical-process-died-help/
Just reinstall windows and save the head ache, there might be a block in the hard drive that is mess up but you can try running SFC scanner and check that everything is good.
MSI Radeon R9 270X
Carbide Series SPEC-02
AMD Black Edition FX‑6300 3.5 GHz
970 MSI gaming motherboard.
Samsung 850 EVO 250GB
HHD 1TB
Kingston HyperX FURY 8GB 1866MHz DDR3
I'm trying to, but it won't let me it says that the drive is locked. I also cannot boot into windows
wait block by what ? can you run the command prompt in safe mode ?
MSI Radeon R9 270X
HHD 1TB
1 minute ago, Max_Settings said:
Like when I go to reinstall it say, "The drive is locked please try again later." Also what should I type in command prompt?
Interesting never encounter an issue like that...
  1. type bootrec /RebuildBcd and press Enter on the keyboard.
  2. Type bootrec /fixMbr and press Enter.
  3. Type bootrec /fixboot and press Enter.
  4. Finally, type Exit and press Enter.
  5. The computer should reboot and allow the refresh or repair of Windows 10 to complete.
MSI Radeon R9 270X
HHD 1TB
Any idea why on her PC after the error is says "preparing automatic repair" and then does that forever?
windows 8 or windows 10 ? it has happen before to people i know but i just reinstall the windows instead of repair it because it's annoying xD
MSI Radeon R9 270X
HHD 1TB
10, but if I can't get into recovery I can't even reinstall
Do you get this screen ?
MSI Radeon R9 270X
HHD 1TB
18 minutes ago, Max_Settings said:
I can only get to that screen if I plug the drive into my PC
trying repairing it in your pc
MSI Radeon R9 270X
HHD 1TB
plug drive into your system then run chkdsk
but this seems like a firmware issue which means a reflash of the firmware to the drives control board
windows does not do this
get the drive manufacturers repair tools on your working system then run repair on the drive
Never thought that ssd can be locked like a micro sd, how is it now?
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
