so sorry I haven't posted on my previous post to give y'all a heads up but my pc somehow works perfectly fine (phew) but so my house  (where the "pc didn't work" according to my brother but it does work) has SO MANY godamn fleas (idk if it's my cat or what... we also live in the country) well mom texted me and saying tonight she's bombing the house will my pcs be okay due to her bombing one in my room and one in living room (my room has all the pcs) why I am asking is my pc and i/o shield don't fit right together (even though the back side of the motherboard where all the usb's and stuff fits perfectly fine) and basically I don't have an io shield connected on either 2 pcs will it be okay? the "bombing" thing is a misty type thing that goes on for about 4 hours non stop spraying
MY MAIN BUILD AT FATHERS HOUSE!
CPU: AMD FX-8300 3.3GHz 8-Core Processor CPU COOLER:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard
RAM: 32gb ddr3
Hard Drive:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Graphics Card:  MSI Radeon RX 470 DirectX 12 Radeon RX 470 ARMOR 4G OC 4GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Case: Rosewill TYRFING ATX Mid Tower Case
Network Adapter:  TP-Link TL-WN781ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter
Case Fans:  Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm Fan (PLUS THE STOCK CASE FAN)
Monitor:  Asus VG248QE 24.0" 1920x1080 144Hz Monitor
Keyboard:  Thermaltake CHALLENGER PRIME Wired Gaming Keyboard
Mouse:  MSI Interceptor DS B1 Wired Optical Mouse
Speakers: Logitech Z200 0W 2ch Speakers
https://linustechtips.com/topic/793046-will-it-be-okay/
Well I would at least turn the pc of so the fans dont suck the stuff in. If you are worried just remove the pc from the room during the process.
Perhaps the manual on the "bomb" can help out? pretty sure there will be something on there saying dont do this or do that.
https://linustechtips.com/topic/793046-will-it-be-okay/#findComment-9987556
Don't just take the PC and put it into another room.  That bug bomb stuff will travel throughout the house.  If possible, remove the pooters completely from the house.  But, if that is not an option, cover the computers with plastic garbage bags making sure the cables are tucked in as far as possible.  Of course, make sure the pooters are turned off first.
https://linustechtips.com/topic/793046-will-it-be-okay/#findComment-9987591
