Posted June 14, 2017 Hello LTT, I am trying to find two good 120mm fans for my H100i v2. I was thinking to install 2 of them behind the radiator. The two that came with the cooler was installed in front of the radiator at the front of my case. Do you guys know any good 120mm fans that I could use for H100i v2? I was thinking my budget should be a low as possible yet a decent fans. Thank you, Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
