Need HELP finding a Laptop Cooler
Hey guys! I have browsed almost the entire internet I guess, and still no luck!!!
I am looking for a RGB Laptop Cooling Solution!! Can anyone help me find one! Again, its important that its RGB or at least i need it to have white and blue and be able to choose between them
Laptop coolers don't make much of a difference, don't bother wasting your money on one. If your laptop is overheating enough for it to be a problem, you are using it for things it wasn't made to be used for, or you have some kind of hardware fault or a virus of some sort using up CPU power.
there is no RGB laptop cooler at all probably never
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
Just curious, why worry about RGB for a notebook fan?  It's not like the notebook has windows you can see the inside through.  No reason to pay extra for something that you can't see, right?
I know they don't make much of a difference, I just need it to look cool! I have a gaming laptop that I currently use, and just thought it would look cool in my office :)
Actually my laptop performs pretty well
I was thinking maybe buying a little oversized cooling pad the lighting would come through on the sides, and probably a little underneath
Somebody should make one! :P
Its really pointless
You're probably right!
Yes because you wont see it a majority of the time
