Hi guys, I'm ready to order. I already purchased the supernova g3 650w psu because it's tier 1 and I had a great deal.
Any improvements on this build ? This will be a RGB Build.
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($427.29 @ shopRBC)
Motherboard: Gigabyte - GA-AB350-GAMING 3 ATX AM4 Motherboard  ($157.48 @ NCIX)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3200 Memory  ($220.48 @ Newegg Canada)
Storage: Crucial - MX300 525GB 2.5" Solid State Drive  ($209.98 @ Amazon Canada)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($67.98 @ Vuugo)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB SC Black Edition Video Card  ($1007.98 @ Amazon Canada)
Case: Phanteks - ECLIPSE P400S TEMPERED GLASS ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Case Fan: Corsair - SP120 RGB 3-Pack w/Controller 52.0 CFM  120mm Fans  ($72.34 @ DirectCanada)
Monitor: LG - 27UD58-B 27.0" 3840x2160 60Hz Monitor  ($451.48 @ Newegg Canada)
Other: CableMod Individually Sleeved Extension Cables Set With Combs 1X24 1XEPS 1X8 1X6 Pin - White  ($28.81 @ DirectCanada)
Other: supernova g3 650w (Purchased For $125.98)
Total: $2895.78
Generated by PCPartPicker 2017-06-13 00:12 EDT-0400
thank you
There isn't anything to change here, sorry that you wasted your time making a post and creating a pcpartpicker list to come up with nothing. But I mean it. There is nothing to change. It's perfect already. Go home, have some rest and start ordering parts, knowing you did a fantastic job creating that build.
30 minutes ago, deXxterlab97 said:
-snip-.
I'm going to assume you are correct, night theme users are going to nope the f out though (as I just did lol)
Aside from that what I can see is awesome, 10/10
Want to custom loop?  Ask me more if you are curious
