It does not matter, it is not directional.
https://linustechtips.com/topic/791274-radiator-help/#findComment-9967195
Sounds like user error. The row and channels aren't directional. If they were they would be marked or the manufacturer would say so.
https://linustechtips.com/topic/791274-radiator-help/#findComment-9967332
