MSI motherboard sound quality?
Go to solution Solved by ARikozuM,
No onboard WiFi. You'll have to purchase a PCIe or USB WiFi card/dongle.
As far as the audio chip, it'll do more than enough for you. The static issue has been gone far long enough that an add-in card will do nothing unless the chip is bad in the first place.
If you want better sound after trying the onboard audio chip, look into a DAC. Don't ask me about them, though.
Hello. I am planning on using the MSI - B250M PRO-VD Micro ATX LGA1151 Motherboard for my gaming PC build. I have heard that using the onboard sound card might result in receiving electrical interference, but MSI advertises the motherboard with good aound quality. I generally use a pair of audio technica m40x headphones so I was wondering if i might be affected by the interference(by the way I only use the headphones for gaming or plain media consumption).
While i'm on the topic, does this motherboard come with onboard wifi or will i have to purchase an onbard pcie wifi adapter? Thanks in advance for all of your help.
https://linustechtips.com/topic/791102-msi-motherboard-sound-quality/
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
