My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
https://linustechtips.com/topic/791004-help/
7 hours ago, pxnguinPr3 said:
Im not sure but in future could you be more specific than "Help" in your title please.
Sorry, I was in a rush.
7 hours ago, edward30 said:
You could just search for "computer desk with wheels" on amazon.com. I did and got plenty of fitting results.
I get actual desks when I search it up. I already have a desk and just want the dolly.
6 hours ago, MUD03 said:
I have my pc on one of those metal pole/wire shelves. They can accept wheels if that's what you want. If you only want wheels on one end the feet that come with it are adjustable so just get two wheels on one side and extend the feet out on the other.
Picture please.
6 hours ago, NLD1st said:
Just get some wood glue, screws, wood and 4 wheels and make one your self ?
Shouldn't be the most complicated. You could even drill vent holes in the bottom if needed.
Ill think about it.
My Rig
 Peripherals
https://linustechtips.com/topic/791004-help/#findComment-9965541
For what use exactly? For PC? For drawer? For cabinet? Or just dolly in which case you could buy the one you linked or make one yourself.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/791004-help/#findComment-9967081
A dolly to hold my pc. I already bought this one.
http://www.ebay.com/itm/191866242859?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
My Rig
 Peripherals
https://linustechtips.com/topic/791004-help/#findComment-9968917
