please don't try anything of that sort....it is very risky business and the returns are not worth it!!
PC 1: CPU: i5 12600k     GPU: RTX 4080     MOTHERBOARD: Asus B650M-A D4       RAM: 16x4 DDR4 3200       POWERSUPPLY: EVGA 650 G6
SSD: WD Black gen 4 x2 + Crucial MX 500 x2
KEYBOARD: Keychron K4    MOUSE: Logitech G502 SE Hero   MOUSE PAD: Goliathus control XL   MONITOR: Alienware AW3423DW + LG 25UM58 + Dell 24"  Speakers: Edifier R1280T + SVS PB1000
Laptop: M1 MacBook Pro 16
https://linustechtips.com/topic/791-cpu-lapping/#findComment-10068
Yes it will help
No it is not worth it unless you do it just for fun. its quite risky and your warrant voids (doh)
"People assume that time is a strict progression of cause to effect. But actually from a non-linear, non-subjective viewpoint, it's more like a big ball of wibbly wobbly timey wimey stuff."
Dont understimate my skillsz, you might look foolish.
https://linustechtips.com/topic/791-cpu-lapping/#findComment-10568
As far as I'm aware' date=' people still lap Sandy Bridge processors to improve temps, if it's necessary. With Ivy Bridge, delidding is apparently the way to go.[/quote']
Sandy bridge chips were soldered to the IHS, so lapping the IHS would improve cooling performance.
Ivy bridge had TIM between the chip and the die, so delidding it would be a lot more beneficial than lapping. Also, running it without a lid altogether would be best; it'd be risky, but would have the best temperatures.
https://linustechtips.com/topic/791-cpu-lapping/#findComment-11103
the die isn't the problem. it is the razorblade thing.
you cant put your razorblade more than 2mm under the IHS, because you will cut in some small capacitors under the IHS.
Running it without IHS isn't a problem, a lot of chips had, and still do have no IHS (for example amd graphicscards and various chipsets).
https://linustechtips.com/topic/791-cpu-lapping/#findComment-11494
