Hello
I downloaded a Linux Mint 18.1 ISO and it says that I should verify it. But I can't download the files I need to do so. Is it even necessary to verify the ISO?
Thanks for your hlep!
 -+-+- This is a reminder to clean the dust filters of your PC! -+-+-
Main PC:
Ryzen 5 1600 3.8GHz - RX 570 4GB - 2x8GB DDR4 - ASUS Prime X370-Pro - Shadow Rock 2 - Define S - Seasonic Prime Gold 650W
500GB NVME SSD - 1TB SATA SSD - 1TB HDD - Windows 10 Pro
Dorm PC:
i5 4590 - GTX 960 4GB - 2x4GB DDR3 - ASUS H81M2 - Dark Rock 3 - Define R3 - 250GB SATA SSD - Seasonic S12 430W - Windows 10 Pro - Linux Mint
NAS:
Pentium G4400 - 4GB DDR4 - Fujitsu Esprimo P556 - 250GB SATA SSD - 2 x 4TB NAS HDD - 12V PSU - OpenMediaVault
Laptop:
Dell Latitude E6520 - i5 2430M - 2x4GB DDR3 - 250GB SATA SSD - Windows 10 Pro - Linux Mint
https://linustechtips.com/topic/790836-need-help-installing-linux-mint/
it does help prevent errors in installation. follow instructions here
https://linuxmint.com/verify.php
download text file from ^ that contains the checksum hash value.
perform sha algorithm on your iso. are you using windows? CertUtil -hashfile linux-mint-filname.iso SHA256
compare the output of sha with the text file.
I like to download iso files by torrent because it has built in verification that I find makes downloading more successful than downloading from web browser. I have downloaded a lot of iso installers and I have not yet had one fail from torrent.
ψ ︿_____︿_ψ_
Main PC:
Dorm PC:
NAS:
Laptop:
you can download the checksum file. You are just doing it wrong.
https://ftp.heanet.ie/mirrors/linuxmint.com/stable/18.1/sha256sum.txt
here are its contents
469b346800c71a60bd7204e03d4cc909c2dc1099f6fc1eaade320411f0fd2990 *linuxmint-18.1-cinnamon-32bit.iso
b99f4b98a1b41737ded072dc1a7060ca32224e23236074790d4fc86b51009e3c *linuxmint-18.1-cinnamon-64bit.iso
a478284343313cabc59fa8867a8e21a899a979665f273ab3a4e6a9641af284c1 *linuxmint-18.1-kde-32bit.iso
62e144db08600ab0be08bdd8489dfb615c401899af869fa0c29679bc866d9dc5 *linuxmint-18.1-kde-64bit.iso
6870a73d8e4667ed6799930be926c0e035e8596e1efc8bd399d7bd987dadae84 *linuxmint-18.1-mate-32bit.iso
b41c5258c03bd8fe4ecab5f1db33f4484bd1992ec306ea4bdde25fc7d6ea2f40 *linuxmint-18.1-mate-64bit.iso
44054c7cf5229d697570222608e352f5e247fcb8981683c871cf3c117c576e70 *linuxmint-18.1-xfce-32bit.iso
7dc167bd5e6e28641c8aaaf406bba46b1be2d472f85d1d86280ed80e19bb8462 *linuxmint-18.1-xfce-64bit.iso
ψ ︿_____︿_ψ_
never done it and never had problems installing mint but i know its recomended so its up to you to do it.
Builds:
Thanks for your help! But this link doesn't work for me. I get an error message when I open it.
Main PC:
Dorm PC:
NAS:
Laptop:
