Recently my computer broke and I troubleshot it and found my PSU was dead... So I looked on the box for warranty stickers but did not find any so I wonder if amazon will let me return my PSU. I looked online trying to figure it out and I was wondering if I should get a better PSU like a silver or gold power supply would it be less likely to break? Also the PSU had plenty of room for airflow. Also I was kind of wondering if it was my power supply in the first place... Here is what happened: So one morning I woke up and my computer was off and the power button was blinking.(it was left on with no games running. And I obviously didn't touch it during the night) So I tried turning it on to my demise. (Didn't turn on) So I turned off the power supply, waited a few moments and then turned it back on. I then pushed the power button and it turned on for about 3 seconds... I then heard a small pop and saw smoke rising from what seemed to be the power supply basement or the graphics card. It then turned off and the power button started blinking again. So I brought it to a work bench plugged only the power in and tried turning it on... I had a freind look with me and all of the fans were spinning and the gpu led came on(the power could come from the 8-pin and the pci-e could have shorted) and it turned on for about 4 seconds but we smelled a burning smell. Shortly after it turned off again and the power button started blinking.
PSU: EVGA 700 b1
Case: NZXT H440
Shouldgestions?
https://linustechtips.com/topic/790727-dead-power-supply-return-help/
You should have a 3 year warranty just contact EVGA
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
Refer to specific models, not just marketing.
Silver and Gold have nothing to do with the actual quality of the PSU.
Pop a question or two in this thread, or pick something from tier 1-3. (tier 1 being the highest.)
How long have you owned this PSU?
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
I have had it for 6 months
EVGA B1 isn't that great
Don't judge PSU quality by efficiency
And don't cheap on PSU
IMO get a new PSU that has a better quality
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
You can see if Amazon is able to give you a hand (e.g. speed up the RMA process), but you should be getting in touch with EVGA directly.
The B1 PSUs have a 3-year warranty through EVGA.
  1. Start the RMA process for your EVGA 700B
  2. Get a hold of another PSU (e.g. from a friend) and make sure nothing else in your computer is damaged / fried
  3. Consider getting a higher quality PSU (e.g. EVGA G2/G3/P2), and selling the 700B once you receive a replacement
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
The model you have has a 3 year warranty, contact EVGA and they should set you up
