I'm building a home/work PC for a family member and am stuck between two CPUs that I can pick up for the exact same price new.
i5-7600
R5 1600x
They will both have the Hyper 212 as I got a spare.
The RAM is 16GB (2x8) DDR4 @ 3000MHz.
The stuff they will be doing includes:
Heavy web browsing and video streaming.
Excel and other MS Office stuff.
Database work.
and other general purpose work.
I'm aware of the spec differences however I'm unaware of which would be utilized better.
Got any questions just ask.
https://linustechtips.com/topic/790057-need-help-deciding-on-a-cpu/
R5 1600 (non X, just OC it). It will waste the i5 in basically anything, because it's got 2 more cores and 3x more threads than the i5. i5s are basically dead now.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
According to specs, the ryzen cpu will likely perform better than the i5. The R5 1600x is a higher TDP chip and doesn't come with a CPU cooler. The Ryzen CPU is hexacore (6 cores) hyperthreaded to 12 threads, while the i5 is a quad core (4 cores) with no hyperthreading.
i5 has a 4.1 ghz boost clock
R5 has a 4.0 ghz boost clock
For your work load either CPU would be adequate. But personally I would invest in the R5 1600x because it is overclockable and has more threads for near same clock speed.
http://cpu.userbenchmark.com/Compare/Intel-Core-i5-7600-vs-AMD-Ryzen-5-1600X/3890vs3920
it's interesting to look at this as even though the R5 has more cores, the i5 seems to boast better performance per core.
Current Specs:
Intel Core i7 6700k
RTX 3060ti
32gb Corsair Dominator Platinum 3000MHz DDR4
Asus Z170 Pro Gaming ATX
Corsair RM850x PSU
Corsair H55
1TB Seagate SSHD
4TB Seagate Barracuda
500GB Hitachi HDD
256GB Samsung 960 Evo M.2
BeQuiet Silent Base 800
Corsair M65 Pro RGB
Corsair K70 Lux RGB
Roccat Taito
Xbone Controller
Logitec Z333
Samsung SyncMaster SA10
LG Ultrawide 25"
the answer is Neither go with a R5 1600 it is cheaper and should serve them just as well. The other thing is that the 1600x doesn't come with a stock cooler and both the 1600 and 1600x will outperform the 7600.  I would recomend going to microcenter they have good prices.
What he said. 1600 will obliterate the i5 in anything especially in video streaming and the like.
1 minute ago, Mastealth said:
I can get the 1600x cheaper than 1600 (deal I got with dealer)
If you can get the 1600X cheaper, go for it. Though you'll need a CPU cooler, so it may not turn out to be cheaper after all (the 1600 includes a decent cooler, and I think it has a lower TDP).
Mouse: EVGA X17
It does indeed have lower TDP.
I got the Cooler Master Hyper 212 already and the brackets to fit both so cooler isn't an issue.
One question correct me if I'm wrong but does the 1600X have an iGPU?
No but it is easy to just grab a gtx 210 for some video outs
Goody. Which, AFAIK, means it's easier to cool, as it doesn't have as large of a potential heat output. Thus why the included cooler is still good.
Mouse: EVGA X17
